I'm interested in using the KFLOP user programs to actually cut parts. I'm very familiar with C, and the opportunity to use a capable, structured programming language is very attractive.
I found the "KMotionDef.h" file, which has some clues as to the "API" of KFLOP.
It looks like all the native motion commands are in "absolute coordinates", which I suspect is encoder counts for our CNC router with brushless DC motors and encoders.
If I want to move in a straight line from a point in 3-space ABC to a second point XYZ at a particular rate, I suspect I need to call
int NoJerkControlAtStart,
int NoJerkControlAtEnd,
int Start);
and then call
StartMove()
There is also
--> Which calls should I use to move in a straight line, at a predetermined rate?
--> How can I know when the move completes?
--> Do you have any comment on the advisability of using this approach?
Hugh
